Jun 7, 2024 5:18 AM UTC
Scanned document with manual mark ups
Can docsign be used to sign scanned documents with manual mark ups?
Michael.Rave
Jun 7, 2024 7:29 AM UTC
@David Cheng
Yes, you can upload any type of document and if the scanned documents contain manual mark ups, there is no problem with putting them into the signature process and signing them like every other document.
Michael.Rave
@David Cheng
Jun 7, 2024 7:50 AM UTC
Thanks Michael. Very helpful.
Jun 21, 2024 9:40 PM UTC
Hi @David Cheng,
