Conversation Starter
May 15, 2025 10:59 PM UTC
Required field review for all collaborators, as part of workflow?
I’m building a template with collaborative fields assigned to Party A but I want Party B to also be guided to these fields regardless of if Party A has already input an entry.
Previously DocuSign allowed me to assign a field to 2 parties though this feature seems to no longer be available. If I could assign the fields to both parties that would probably be ideal, but the core issue is I want each party to be forced to go through these fields and not just skip to fields that are assigned directly to them.
Any suggestions?
May 26, 2025 5:37 PM UTC
Hello ​@Office_Tech732,
I hope you’re doing well.
To confirm, when you apply a field, the “Collaboration” is not showing on the left panel?
If you were able to use it before and did not make any changes to your account plan, I would recommend that you open a support case to confirm if the feature is disabled and if they can enable it for you. Open a case in the Docusign Support Center
Established Contributor
May 16, 2025 9:18 PM UTC
Why not drag an Initials block for Party B to each instance you need them to see?
May 23, 2025 11:08 PM UTC
I want to confirm if you need further assistance. Feel free to let me know, and I will gladly help you address the situation as soon as possible.
May 23, 2025 11:46 PM UTC
I like the signature block idea, maybe use a Note and an initials field, indicating they’ve reviewed the changes.
One thing that makes it kind of clunky is If Party A made no changes then party B has the signature block prompt to initial but there’s nothing to approve, and DocuSign doesn’t allow me to make conditional fields like a note appear to party B based on a text field assigned to party A.
It feels like I’m over thinking it and it shouldn’t be this hard to direct 2 people to the same fields, having them be optional for A and required for B.
Jun 9, 2025 7:04 PM UTC
I hope you’re doing well. If the solution provided helped you, cleared things up, or pointed you in the right direction, please click Best Answer ✅"so others can find it too.
Let us know if we can help with anything else. Wishing you a smooth rest of your day!
