Active Voice
Apr 4, 2026 12:41 PM UTC
Recipients documents very small and hard to read on phone
Hi
Has anyone come across an issue where recipients can’t read the document they receive because it’s very small type and all left aligned on the screen.
The recipient is picking up the DocuSign envelope on their mobile phone, and using their browser to open (not the DocuSign app). See below screenshot.
Apr 7, 2026 1:42 PM UTC
Hi ​@Kenneth,
Thank you for engaging with the Docusign Community. We are pleased to have you here.
I’m sorry to hear you’re having trouble with the documents sent for signature. I understand that the recipient cannot properly view them, as they appear too small when viewed in a mobile browser. I’ll be glad to help.
Based on the screenshot provided, it appears the envelope was not set to the mobile-friendly view. To check, please navigate to Agreements > locate the envelope, select Correct, then click Advanced Options. Mobile-Friendly should be checked. Please take a look at the image below for reference.
Additionally, an administrator can enable the Responsive Signing in the admin settings. This can improve how documents are displayed based on the signer’s device type. This article may be helpful for more information: Responsive Signing.
Once done, please resend the envelope and check if it worked! If the issue persists, kindly provide the envelope ID via private message so I can check and review.
If my response helped solve your concern, could you click the “Best Answer ✅” button below the post? That helps others in the Community find trusted answers faster.
Hi ​@Kenneth,
Apr 14, 2026 2:25 PM UTC
Hi ​@Kenneth,
I hope you’re doing great. I would like to check if the information provided help resolved your concern.
Feel free to click the “Best Answer ✅” button below the post. That helps others in the Community find trusted answers faster.
Thanks for being part of the Docusign Community!
