Apr 8, 2024 11:02 PM UTC
recipent does not have the same view of document as I do when I look in preview. It's a rental lease
I uploaded a template that I already filled out with details. Created signing order. when I select preview only sender can see details. When I view from 2nd signer the document is blank with no details
Apr 8, 2024 11:12 PM UTC
@Anne.Cabrera  - You can change the signers view in Preview mode.  Or maybe you Document visibility enabled for that 2nd signer.   Would you be able to provide more information on the setup?
Apr 23, 2024 4:03 PM UTC
Hi @Anne.Cabrera,
