Oct 8, 2024 8:24 PM UTC
Problem with one field in Bulk Send
I have uploaded my CSV file using the CSV template.  I’ve left some fields empty because I don’t know what they are for.  But one field - Requestor::First Name is not coming through and even though I accept the matching exception, I end up with an error message after I do. The names in the First Name column match the first names that are also included in the Name column...not sure what I am missing.
Oct 9, 2024 6:40 PM UTC
Hello @NStephen ,
Was the CSV created by you? Can you try downloading the sample CSV? If you are using the sample CSV, can you try changing Requester::First Name to Requester::Name?: Generate a Customized CSV File for the Bulk Recipient List
Hello @NStephen ,
Oct 24, 2024 7:14 PM UTC
Hello @NStephen ,
Are you able to provide the information that I previously requested? If so, please do so in a reply to this question so that I am able to further assist you with your issue.
NStephenNewcomerAuthor
Oct 24, 2024 9:17 PM UTC
Hello.  Your recommendation got me past the error message.  However, I later found an anomaly that is causing some of the recipients not to be able to add their last name.  🤔Something to figure out for the future...
Oct 25, 2024 6:34 PM UTC
Hello @NStephen ,
Thank you for reaching back.
Are they getting an error? Can you provide more detail on what they are experiencing?
Nov 8, 2024 7:47 PM UTC
Hello @NStephen ,
