Apr 10, 2024 9:31 AM UTC
Problem...
I’ve started a monthly subscription, but it isn’t allowing me to start and sign. Does anyone have any ideas? Thanks in advance.
Vinicius.Rodrigues
Apr 10, 2024 8:59 PM UTC
Hi @Darcyrae !
Please, try to log off and than login again. If the issue still happen, check if your payment was approved by the system and you have a monthly plan attached in your account by accessing Settings (must be an Admin) > Plan and Billing. Also, check this article for more information: How do I update my payment information?
For additional questions or if you didn’t solve the issue, please, contact your DocuSign Account Team. If you don't know how to contact them, log in to the DocuSign Support Center and create a case to get help.
Vinicius.Rodrigues
Hi @Darcyrae !
Apr 24, 2024 11:26 PM UTC
Hi @Darcyrae,
