Aug 16, 2024 9:22 AM UTC
Pre-fill Fields lock for clients
We need to lock pre fields for clients what's is the process
Aug 18, 2024 8:34 PM UTC
@munish 4 veda
Thanks for your question! I want to make sure I fully understand what you're asking so I can give you the best answer. Could you please clarify what you mean by “need to lock pre fields for clients what's is the process”?
Sep 2, 2024 12:27 PM UTC
Hello @munish 4 veda ,
Are you able to provide the information that was previously requested? If so, please do so in a reply to this question so that we can further assist you with your issue.
Kevin.Ponseel
Sep 2, 2024 1:54 PM UTC
You just have to mark them as Read-Only Fields
https://support.docusign.com/s/document-item?language=en_US&rsc_301&bundleId=ulp1643236876813&topicId=lek1578456504446.html&_LANG=enus
Have a great day
