Mar 6, 2025 2:34 PM UTC
Powerform problem
I am having trouble with creating a power form. Everything looks ok on the back end and boxes are all matched on the form, but when we use the url I get an unfillable pdf and I receive a ‘completed’ email notification. Please help
Mar 7, 2025 9:08 PM UTC
Hello ​@JRiley,
Thank you for reaching out, and welcome to the Docusign Community! We are glad to have you here and can't wait to help share as much knowledge as possible.
I am sorry to hear about the issue you’re experiencing with PowerForm creation. I understand that when you use the PowerForm URL, it results in an unfillable PDF, and you receive a ‘completed’ email notification. I sincerely apologize for this issue, and I’m here to assist you in identifying the cause and resolve this. To do so effectively, I have a few questions that will help me better understand the situation and provide an accurate resolution.
  • Is the problem the same when you send a test envelope to yourself using the template?
  • How many recipients do you have, and what actions are required from them (for example: Needs to Sign, Needs to View)? Is there a specific Signing Order?
  • Have you verified that the fields in the template are correctly assigned to the recipient/s?
  • Could you please describe the step-by-step process you did and the behavior observed after accessing the Powerform URL?
  • Can you create a new Powerform from scratch using the same template to determine if the issue persists?
  • If the issue continues, are you able to download the template and share the JSON file? Here's an article: Download Templates
I looking forward to hearing back from you. Thank you!
Mar 14, 2025 9:22 PM UTC
Hello ​@JRiley,
I want to confirm if you need further assistance, feel free to let me know and I will gladly help you address the situation as soon as possible. Thank you!
