Tim Charbonneau
Conversation Starter
May 30, 2024 7:31 PM UTC
Power Forms
I’m trying to create a new Power Form and and get this message: “Cannot create a PowerForm from the selected template. Direct signing mode is not enabled for PowerForms.”  I can’t find any answers or workarounds for this message.  Please help.
Tim Charbonneau
May 30, 2024 7:41 PM UTC
Also - Our Company has three accounts - one for each brand. I don’t get this error message in the other account.
Stay Safe and E Sign
May 30, 2024 7:47 PM UTC
@Tim Charbonneau - The error message "Cannot create a PowerForm from the selected template Direct signing mode is not enabled for PowerForms" indicates that the template you are trying to use does not have Direct Signing Mode enabled, which is required for creating PowerForms.
Tim Charbonneau
May 30, 2024 9:19 PM UTC
Is tjis a setting I can control ? Or does DocuSign support do it?
May 30, 2024 10:17 PM UTC
@Tim Charbonneau - What actions can be taken on your template for each role.   For example, a template cannot be used for a PowerForm if a role is set to Specify Recipients or In Person Signer.
Tim Charbonneau
Jun 3, 2024 2:51 PM UTC
Thanks for your reply  - Those settings are correct, DocuSign support has elevated this to next level support. FYI- we have three sub accounts and it only happens in 1 , the other two are working fine. Scratching my head. T
Jun 19, 2024 12:20 AM UTC
Hi @Tim Charbonneau,
