Apr 19, 2024 10:18 AM UTC
Part 11 Module with Siging Group
Hi all,
is it possible to assign a signing group while using the Part 11 Module?
I tried and cannot find the signing group while creating the template.
Best regards
Ryan
Inki.KimAnswer
Apr 19, 2024 11:52 AM UTC
Hi Ryan,
Signing groups are available for CFR Part 11 accounts.  Please keep in mind that the signing groups must be created by an administrator on the account in order to be used as part of a template.  If you’re an admin and don’t see that option in your settings, you can reach out to your account team or DS Support.
Inki.KimDocusign EmployeeAnswer
Hi Ryan,
ZQLNewcomerAuthor
Apr 19, 2024 12:41 PM UTC
Hi Inki,
Thank you for the response.
In my case I do not have the admin rights. Instead, my colleague who has the admin rights has created the signing group for me.
Best regards
Ryan
May 3, 2024 3:42 PM UTC
Hello @ZQL ,
