Oct 24, 2024 4:33 PM UTC
OCR post signatures - Optical Character Recognition
Some documents are not OCR’d when signatures are completed.  Odobe will not ODC documents post-signatures. If there a setting we can use to ensure documents are OCR enabled before signatures and, is there a process to OCR post-signatures?
Our documents are stored in SharePoint and being able to search the document text/content is important for our organization.
Thanks,
Mary
Oct 25, 2024 5:01 PM UTC
Hello @marymekk,
Are you sending the document via the Docusign Web App or are using an integration? If an integration is being used, can you provide the name?
Nov 8, 2024 10:26 PM UTC
Hi @marymekk,
