May 2, 2024 3:31 PM UTC
Not able to send sender permisions
I’m getting the following error message when trying to send a document:
To send, you must complete the 1 pre-fill feilds with sender permissions.
I don’t know how to fix this…
Alexandre.Augusto
May 2, 2024 7:17 PM UTC
Hello, @Footsteps
If the envelope has pre-fill text fields then they need to be filled out before you press SEND.
See this example:
There are two pre-fill text fields, they need to be filled out so you can press the SEND button.
If you try to send with those fields in blank, this is the error message:
Let me know if I answered your question.
Best,
Alexandre
Alexandre.Augusto
Hello, @Footsteps
See this example:
Best,
Alexandre
May 16, 2024 10:06 PM UTC
Hi @Footsteps,
I would like to confirm if you were able to solve your issue by utilizing the solution that was suggested or if the information that was provided was useful.
Otherwise, feel free to let me know and I will gladly help you address the situation as soon as possible.
Jul 2, 2025 10:52 AM UTC
 the envelope has pre-fill text fields then they need to be filled , how to identify which field need to be pre filled
Jul 4, 2025 4:35 PM UTC
Hi ​@neha_kumari,
Great question! Pre-fill fields are fields in gray color.
You need to pre-fill those fields before sending.
I hope this is helpful. Let me know if you have questions or if anything comes up. Thanks!
Helpful? Mark it as "Best Answer" to help others too!
Jul 18, 2025 6:53 PM UTC
Hi there ​@neha_kumari,
I'm just checking in to see if you still need any help, and we'll gladly help you with any questions you may have. 😊
Have a great day!
