Nov 3, 2025 6:37 PM UTC
Need help with bulk email templates using custom fields
Community,
Need some help with bulk sending please!
My custom fields are not being recognized when starting an envelope, then opening the template, and selecting the csv below. When I download a sample csv, it doesn’t have most of the custom fields that have been created.
I’m sure the csv header is not pulling across or formatted correctly.
Thanks!
Nov 11, 2025 6:53 PM UTC
Hi ​@hqbrevid—we're truly sorry for this issue you're having. Together, we can sort this out!
First, please verify that all your custom fields are properly added to your template. We recommend renaming each custom field's data label to something clearer and more descriptive.
Here's what you can do next: Edit your Template. Drag and drop custom fields to the document and update the data label, or use standard fields and rename the data label accordingly.
  • After saving your changes, use your template > click  Advanced Edit > select Bulk send and download the Sample CSV file. This time, the CSV should automatically include columns based on the fields you added.
For detailed instructions on the bulk sending process, please refer to the articles:
Bulk Send Work Process
Prepare Documents to Integrate Data From the CSV File
Generate a Customized CSV File for Bulk Recipient Lists
We hope this helps you move forward smoothly. If you are still experiencing issues after following the steps above, we recommend opening a support case so our Technical Team can take a closer look at the issue via screen sharing 👉 Open a case in the Docusign Support Center
Here if you need us!
Nov 4, 2025 12:22 AM UTC
​@hqbrevid
You need to assign the custom field to one of the recipients even if it just a read-only field.  You CSV should have Role1::Envelope Custom Field 1 or Role2::Envelope Custom Field 1 or any other Role.
hqbrevidNew VoiceAuthor
Nov 4, 2025 4:17 AM UTC
Hi John, that doesn’t work.
Nov 4, 2025 2:57 PM UTC
​@hqbrevid
Are the custom fields on the Template?
Nov 4, 2025 3:56 PM UTC
Yes
Nov 19, 2025 11:54 PM UTC
Hello again ​@hqbrevid,
I trust all is well. We’d like to know if the suggested solution was helpful. If yes, we would greatly appreciate it if you could give it a Like👍and mark it as "Best Answer" ✅, to help other community members find trusted answers.😊
Let us know if you need further assistance—we're here for you!
👍and click "Best Answer"
