Jul 7, 2025 8:44 AM UTC
Need help integrating my PayAsYouGo DocuSign into my application
I have DocuSign Pay-As-You-Go account. I am developing an application. From within that application, using APIs, I want to be able to send DocuSign envelopes to my clients and get e-Signatures. I have 100's of clients and we expect to have several envelopes to be sent every year, per client.  Do I have to be a DocuSign partner for this?  It appears that I cannot use our PayAsYouGo Account (see screenshot below).  When I look at IAM Standard plan, it doesnt tell me if I can do unlimited e-sign envelopes to my clients…. but it says unlimited webapp sends.  Not sure if API call and web app sends are same.   DocuSign integration that I own into an app I am building must be much simpler than this!!
  Please HELP!
Vinicius.Rodrigues
Jul 8, 2025 12:37 PM UTC
Hi ​@CodeGen !
Actually, WebApp and API calls are different things. WebApp refers to when you’re using the Docusign IAM platform through a browser (not integrated using API calls).
Our IAM platform can support API calls, but it will depend on the account plan you have purchased. I highly recommend that you submit a case with our customer support, so they'll be able to explain to you all the details and limitations about your current plan, to make a safe decision if an upgrade is necessary or not.
Based only on the image you are sharing, I would say that this current plan does not support the API calls required for this type of integration, but really only the customer support team can confirm this.
Please, let me know if I was able to help you with this question. If so, could you please select click on the "Select as Best" option? Thank you!
Vinicius.Rodrigues
Hi ​@CodeGen !
Jul 15, 2025 4:10 PM UTC
Hi there ​@CodeGen,
How are you? I'm checking in to see if the solution provided has been helpful. If it has, may you please mark it as Best Answer ✅? This will help others with similar questions find the solution more easily. 🙂
Let us know if you still need help or if anything else comes up, we’re here for you.
