Active Voice
Nov 7, 2024 4:59 PM UTC
Need help
We send lots of grants for signature and sometimes one grant can go to 32 boroughs / 32 people who need to sign
do you have any ideas of an easier way to send multiple documents (different documents) to different people for signature without having to upload them one by one on docusign?
Nov 8, 2024 6:09 PM UTC
Hello @Sayed ,
Thank you for reaching out here in the Docusign Community.
If the documents are going to be different each time, unfortunately, there isn’t a way to do that. The products Docusign offers (Bulk Send, PowerForms and Web Forms) require the documents to be the same. Bulk send allows you to send the same document but with different information. If the documents are going to be different each time but require the same information, you might be able to create a place holder template with the needed fields that you can just apply to the actual document: Apply Templates Manually
Hello @Sayed ,
Nov 22, 2024 6:46 PM UTC
Hello ​@Sayed ,
