Apr 2, 2025 8:06 PM UTC
Need a solution to my problem
I have a DocuSign and need to attach add a excel document to it.  It will not open up and attach to the DocuSign.  Ned help please
Apr 3, 2025 3:59 PM UTC
​@melones
You can definitely upload Excel files to DocuSign, but just a heads-up:
When you upload an Excel file to DocuSign, it gets converted to a PDF format.
That means:
  • You won't be able to edit or interact with it like a normal Excel spreadsheet (no formulas, filters, or multiple tabs).
  • What you see is a static, flat version of the Excel file—basically like a printed version.
Community Admin
Apr 2, 2025 9:54 PM UTC
Thanks so much for posting in the Community! Could you give some more details about the issue you’re experiencing so we can give you relevant guidance?
Leah
​@melones
That means:
Apr 10, 2025 9:23 PM UTC
Hello ​@melones,
