Jul 12, 2024 8:58 AM UTC
Making tick boxes a required field
Does anyone know how I can make tick boxes a required field?
Aug 6, 2024 9:39 PM UTC
Hi @Hetal,
I hope you are doing well, glad to hear that you were able to resolve the issue, perhaps for future reference this guide Specify How Many Checkboxes in a Group a Signer Can or Must Select could be helpful.
Jul 12, 2024 9:39 AM UTC
You need to select the checkbox
Edit the properties
Set the field as required
Then Save
Hope this helps.
HetalNew VoiceAuthor
Jul 12, 2024 10:27 AM UTC
hi, thank-you for responding I was able to work out. It looks like they’ve changed things as you now use a validation setting.
Aug 5, 2024 10:11 PM UTC
Hi @Hetal,
Aug 6, 2024 7:03 AM UTC
I was able to resolve the issue, the tip given was partially helpful, but the layout and terminology has changed so it take longer to work out how to do it.
Hi @Hetal,
