Sep 11, 2024 3:22 PM UTC
Is there a way to set up automatic reminders for every outgoing envelope?
I’d like the default for our outgoing envelopes to include automatic reminders. I’d rather not have to turn them on for each document I send. Is that possible?
Sep 11, 2024 8:59 PM UTC
@Laeni
Yes, you can set the automatic reminders at the account level if you are an Admin on your DocuSign account.  Make sure you uncheck the option to Allow the sender to override the account default.
@Laeni
Sep 25, 2024 10:27 PM UTC
Hi @Laeni,
