Feb 15, 2024 5:32 AM UTC
Is there a way to add a formula to text box?
Hi Community
Is there a way to add a formula to text box? As an example
The signed date + 1 year = automatic comment in a text box
Any help would be appreciated.
Regards
Luke C
Michael.Rave
Feb 15, 2024 8:17 AM UTC
@Luke Crnjac
No, you cannot add a formula to a text field. It only works with the formula field.
It is possible to achieve what you want by leveraging Conditional Fields in DocuSign eSignature and conditionally show the text field, when the formula field is true.
  1. Add your text field and pre-fill the text “Automatic” and make it read-only
  2. Create a formula field to check “Signed Date + 1 Year”
  3. Add an IF function to the formula, so the value is 1 is when true and 0 if not
  4. Apply conditional logic to show the text field when the value equals 1
DocuSign Support Article on the If function in the formula field:
https://support.docusign.com/s/document-item?language=en_US&bundleId=gbo1643332197980&topicId=mnf1578456360259.html&_LANG=enus
DocuSign Support Article on calculating dates in the formula field:
https://support.docusign.com/s/document-item?language=en_US&bundleId=gbo1643332197980&topicId=gne1578456360501.html&_LANG=enus
DocuSign Support Article on Conditional Fields:
https://support.docusign.com/s/document-item?bundleId=gbo1643332197980&topicId=hew1578456460132.html&_LANG=enus&language=en_US&rsc_301
Michael.Rave
@Luke Crnjac
Feb 29, 2024 2:10 PM UTC
Hi @Luke Crnjac,
Mar 12, 2024 10:13 PM UTC
Hello @YARDPRO ,
I apologize for the inconvenience, you can use multiple formula fields within a formula, can you provide more information about what you are encountering?
