Jun 2, 2022 11:36 PM UTC
Is there a way for sender one to make corrections to their sections of the document once it has been sent to sender two?
I am the sender of a document, the first signer said there was a mistake they entered on their section of the document. Now the document is off to sender two. Is there a way to send the document back to sender one to allow them to revise their mistakes?
Jun 3, 2022 12:10 AM UTC
You can apply changes to any envelope or recipient that has not been marked as completed.
Once a recipient completes their action (or the envelope), the system will not accept any further alterations.  Because of this, you will be required to recreate it.
You can find more details regarding how to correct an envelope, here:
https://support.docusign.com/en/guides/ndse-user-guide-correct-documents
Feel free to let us know if you have any follow-up questions and we will address them as soon as possible.
Alejandro R.
Community Moderator.
Alejandro R.
Jun 16, 2022 8:04 PM UTC
how do u make a correction?
Jun 17, 2022 1:42 AM UTC
You can correct an envelope under Manage>Sent>Actions>Correct.
For detailed steps on the process, please read the guide provided below:
Alejandro R.
