Jun 23, 2023 7:16 AM UTC
Is it possible to merge or Combine two documents and send via DocuSign eSignature? If yes How?
Jun 23, 2023 11:59 AM UTC
Unfortunately, the option to combine documents prior to sending is not possible with DocuSign eSignature, these can only be combined into a single PDF once they have been completed and when you go in to download the document: https://support.docusign.com/s/document-item?bundleId=oeq1643226594604&topicId=ufg1578456341295.html&_LANG=enus
Feedback that can improve our users’ experience is always more than welcome.
We’ll provide it to the Product team that is closely aligned with the area associated with the feedback. They will review it and determine the next steps.
In the near future, we will have a Community section that is dedicated to customer suggestions/feedback. You all will have the ability to upvote on what’s important and needed.
If you’re a DocuSign Administrator for a corporate plan, you have the additional option of filing your request directly when you’re logged into your account. You’ll be able to click the “Give Feedback” button at the bottom of the screen in order to submit your idea.
