Dec 18, 2024 10:45 AM UTC
I need help embedding a document signature on my website.
I am trying to generate a URL to embed a document signature on my website. The URL is embedding successfully, but the problem is that my document template has two roles: "admin" and "user." I want to generate the URL for the "user" role. However, sometimes the generated URL shows the signature area for the admin role, and other times it shows no option to upload or add a signature. I have researched the issue and found a suggestion to check the recipient ID. I checked the recipient ID for the envelope ID "". Here is a screenshot of the generated response: https://prnt.sc/rT1cLFKjmOit. In this response, the recipient ID for the "user" role is 1. Below is the code I am using to make the request to generate the URL for the user role: https://prnt.sc/m-sUNaA98f1O. However, in the iframe screenshot, no signature area is showing: https://prnt.sc/HbuWsiQRMgwz. Please see the issue. Additionally, I received an email for the envelope. When I use the link from the email to sign the document, it shows the signature area and automatically fills in other details as well, as shown in this screenshot: https://prnt.sc/7ZNxIhY3X76o. I want to implement this correctly on my webpage using embadded feature so the user is not required to go to another site for document signature. Can you help me resolve this issue?
Envelope ID removed due to personal information
Hengfeng Ge
Hero
Dec 18, 2024 4:34 PM UTC
please reference this document: https://www.docusign.com/blog/developers/deep-dive-the-embedded-signing-recipient-view
And add clientuserid for embedded recipient .
FreeLink/甫连信息
🌍 Docusign Partner | Partner Profile
🏆 Docusign 2024 APAC Reseller Growth Partner of the Year
🌟 The only Docusign Partner globally certified as both a Certified eSignature Administrator and eSignature Technical Consultant.
📊 Docusign Community Leaderboard Top 5 contributor.
🚀 Expertise in Docusign integrations with on-premises systems for leading enterprises across various industries.
Hengfeng Ge
Hero
Hero
FreeLink/甫连信息
Jan 2, 2025 6:37 PM UTC
Hello ​@expectedprofit ,
If you found the response to be a useful solution to your question, please mark it as the best answer by clicking “Select as Best” to make it easier for other users to find.
