Mar 24, 2023 12:30 PM UTC
I'm sending a lot of test envelopes which is using up the amount in my plan. Is there a way to test sending documents without using my plan amount? Thanks for any help!
Mar 24, 2023 8:50 PM UTC
With the Demo account, you will have the ability to send envelopes without using your envelope quota for your production account, once you have reached a satisfactory result for the template, then you can transfer your template to the production environment to be officially used.
There is no other option than use the Demo/Sandbox account.
Mar 24, 2023 4:01 PM UTC
You can create a Demo/Sandbox account, please see https://developers.docusign.com/platform/account/
Mar 24, 2023 4:14 PM UTC
Thank you Christopher,
I visited the site you suggested. I don't know if that is what I need. I'm working in Smartsheet to create templates to send through DocuSign. I have to send documents over and over until I can get the templates right which means I'm wasting envelopes so I was hoping there was another way to test my documents without using "real" envelopes.
Thanks!
