CorneliusReuter
Conversation Starter
Nov 19, 2024 3:21 PM UTC
How many attachments per envelope?
do anyone know how many documents I can send/attach in one envelope both
  1. for manual sending and
  2. for sending via API
Background: I have different 3,000 documents which have to be signed from exactly 2 signers (the same signer for all documents). And know I’m searching for a good solution. In best case I would attach all 3,000 documents and docusign will place the signing fields automatically (auto-positioning).
Thanks and regards,
Cornelius
Nov 20, 2024 2:15 PM UTC
Hello ​@CorneliusReuter,
Welcome to the Docusign Community and thank you for posting your concerns.
The maximum number of documents that can be added to a single envelope is 130 in both normal sending and in API. With that said, do those 3,000 documents need to be signed separately by other signers?
Dec 5, 2024 11:55 AM UTC
Hello ​@CorneliusReuter ,
