Oct 25, 2022 10:15 PM UTC
How does Powerforms work?
Oct 25, 2022 10:18 PM UTC
With PowerForms, your business can generate on-demand, self-service documents for signature. You’ll be able to eliminate document preparation time (by using a pre-existing template), and easily pull collected data into your existing applications. A link can be generated that can be emailed, sent via SMS (on certain enterprise plans), or embedded into your website.
For more details on how to use Powerforms, please click on the link below: https://support.docusign.com/en/guides/ndse-user-guide-using-powerforms
If you don’t have permissions to create Powerforms, you should contact the DocuSign Admin at your company to see if it’s available.
Do you need assistance with a Powerform that you’ve already created and are working with? Please create a Customer Support case by clicking below:
If you’re not able to open a Customer Support case via the above link, scroll down further on the page to “More Support Options” and select "I can't reset my password or don't have an account." You will have different options to contact Support.
