Mar 21, 2019 7:32 PM UTC
How do I view what Reminder and Expiration dates I have selected for an envelope? These are open documents, and I didn't write down the advance options I chose
Mar 21, 2019 8:16 PM UTC
When envelopes are created they use the default set for the Account. So if the default is set under Admin Console > Reminders and Expirations, every new envelope should use these values by default whether creating one envelope or 300 using bulk send.
Unfortunately if you sent out 300 envelopes and the Reminders were set to 3 days, there is no way to my knowledge to bulk change all 300 envelopes to say 5 days instead. You would need to correct each envelope.
Mar 21, 2019 7:52 PM UTC
If you are the Sender then I would suggest just to go into "Correct" on the envelope, check the values and then exit correct mode (Discard Changes). Therefore you see the settings chosen without making any changes to the envelope.
Mar 21, 2019 8:01 PM UTC
I am the sender. Is there a way to change for all that we bulk sent?
Mar 21, 2019 8:17 PM UTC
Thank you very much!!!
