Apr 3, 2024 6:48 PM UTC
help with check box on form
Hi, I added 2 check boxes for people to click on and when the forms came back to me none of them were checked.  I’m wondering if I added them improperly because I can’t imagine everyone missed that step.  Any help with this issue?
Thanks,
Joyce
Apr 3, 2024 8:21 PM UTC
That might have been the case.   You need to enable Validation on your checkboxes.   Also make sure they are part of the same group.
Apr 18, 2024 12:23 PM UTC
Hello @Joyce Davis ,
