Oct 11, 2024 12:48 PM UTC
Help Using a Template
I am unable to use my templates.  First I click on ‘Upload’ and from the dropdown menu ‘Use a template’, then I select the template I want to use, I click ‘Add Selected’, it spins for several seconds as if it is uploading, a green message comes on the screen indicating ‘Template successfully added’.  But, the template is not there and I can’t move forward to send it out.
Can someone help?
Oct 14, 2024 2:29 PM UTC
Hello @rgoozh,
Have you tried the below troubleshooting:
  • Clear cache/cookies
  • Try a different browser(s)
  • Try an Incognito window
  • Try a different device
  • Try a different Internet network, such as on a mobile device using data with Wi-Fi disabled.
  • Try using a VPN, or if you are on one already, disconnect from the VPN and try again.
Is this happening with all of your templates?
Hello @rgoozh,
Oct 28, 2024 10:59 PM UTC
Hi @rgoozh,
