Aug 6, 2024 10:08 PM UTC
Help me stop Power Form from immediately sending to the next recipient
I’ve got a template where the list of recipients is as follows:
  1. Employee (blank)
  2. Program/Department Director (blank)
  3. Financial (routing group)
  4. Senior Director (routing group)
  5. Executive Director (routing group)
  6. Accounts Payable (signing group)
  7. Accounts Payable (CC)
When I open the Power Form URL, I see the first page, where I input my name and email as an employee and then my supervisor's email as program/department director. The routing and signing groups take care of the rest. When I click on Begin Signing, I’m brought to my template form.
When I click on my template form, the #2 person entered as the program/department director immediately gets an email asking for their document review. If they open the document before the employee completes the required information, they'll see a blank document.
How do I adjust my template/Power Form so the #2 person entered into the workflow doesn’t receive the email to review the document until the first person clicks on Finish?
Thanks in advance!  =)
Aug 8, 2024 4:20 PM UTC
I found it. Somehow, the recipient order had the top two recipients set to 1. For some odd reason, when I tried numbering the second one as two, it automatically set the third recipient as 2. Manually setting the third from 2 to 3 fixed that.
Aug 7, 2024 3:28 AM UTC
@Joshua.Peter
On your template, did you set a Signing Order for the Employee and the Program/Department Director?  This will ensure that the Employee completes their portion of the document before it gets routed to the Program/Department Director.
Joshua.PeterNew VoiceAuthorAnswer
Aug 8, 2024 4:29 PM UTC
I found it. For some reason, the recipient order had the top two recipients set to 1. For some odd reason, when I tried numbering the second one as two, it automatically set the third recipient as 2. Manually setting the third from 2 to 3 fixed that. Odd.
I’m glad you were able to figure it out.
Aug 22, 2024 10:27 PM UTC
Hi @Joshua.Peter,
