Feb 27, 2025 5:55 PM UTC
HELP! I can't open a case
I need the support email address to discuss an issue with my home page. I have tried for two days now and I can’t open a case it keeps sending me to this page and once I chose the service it gives me an error. Does anyone have a direct email to Docusign’s support. This is very unbecoming in not being able to contact someone immediately.
Feb 28, 2025 10:23 PM UTC
Hello ​@Oncor,
I don't see any report or incident related to this issue. Would you mind trying these steps and check if the issue persists? Just in case we have encounter a possible affectation:
1. Clear the cache and cookies
2. Try a different browser(s)
3. Try an Incognito/in-private window
4. Try a different device
5. Test with different Internet networks such as on a mobile device using data with Wi-Fi disabled.
If the issue persists, I suggest you open a case using the link at the bottom of the page.
Hello ​@Oncor,
Mar 7, 2025 6:19 PM UTC
Hello ​@Oncor,
If so, please mark it as the "Best Answer ✅" by clicking “Select as Best” to make it easier for other users to find.
Mar 14, 2025 9:25 AM UTC
Hello ​@Oncor
If you found my response to be a useful solution to your question, could you please click the "Best Answer ✅" button at the bottom of the post?
It helps other community members who might have similar questions. Thank you!
