Apr 3, 2025 8:12 AM UTC
DocuSign for SharePoint does it help for automatic backup documents?
Hello DocuSign Coms,
We are trying to find a way to backup documentations that have been send out to either to Sharepoint or Onedrive. Nevertheless, im not sure this practice from the guideline was correct for the setup - https://support.docusign.com/s/document-item?language=en_US&bundleId=chy1716406964961&topicId=sen1716408519671.html&_LANG=enus
Can i seek help for look out the sufficient guideline or setup practice which can achieve this?
Alexandre.Augusto
Apr 3, 2025 2:01 PM UTC
Hello, ​@Wuang N
Yes, you can backup your envelopes using Sharepoint.
The way to do this is using Agreement Actions. You need first to connect your Docusign eSignature account with a Sharepoint account.
Watch this video to learn more:
I hope that helps, if so, I’d appreciate your Like here.
Best,
Alexandre
Alexandre.Augusto
Hello, ​@Wuang N
Best,
Alexandre
Apr 10, 2025 9:21 PM UTC
Hello ​@Wuang N,
