May 14, 2024 3:58 PM UTC
Detect and auto place
Is there any one at Docusign who is working on detection and *automatic* placement of signatures on scanned pdfs? If so, where can I play with this? If not, what is preventing this from happening?
It seems like this should be possible now that there is Machine Learning.
Thoughts?
May 30, 2024 4:47 PM UTC
Hi @Travis,
Thank you for following up.
Have you tried starting the process by adding a document, instead of taking a photo of the form?
I am wondering if this could be the missing step that could be causing the issue.
Alexandre.Augusto
May 14, 2024 6:44 PM UTC
Hello, @Travis
You are welcome to the Docusign Community!
The detection and automatic placement or tagging is present for example in our Docusign Mobile App, creating an envelope using the App enables an auto-tagging(placement) feature after you add a document then define the recipients. Try using the App.
Since we’re evolving so fast, for example, end of May we will release docusign IAM with a lot of solutions as well AI enhancements.
I invite you to provide your feedback directly to the Product team:
Docusign is committed to your success. Tell us how we can do a better job:
Let me know if that answered your question.
Best,
Alexandre
May 29, 2024 5:21 PM UTC
Hi @Travis,
TravisNewcomerAuthor
May 29, 2024 5:31 PM UTC
Thank you for reaching back out, Alejandro-- I don’t see it in the mobile app. After taking a photo of the form, where will it auto detect the signature locations to place the signature field?
Is there a special setting that needs to be selected?
Hi @Travis,
