lvincent
Active Voice
Active Voice
Nov 26, 2024 3:31 PM UTC
Customizing the Sender and Body of the Verification Code SMS in DocuSign
Is it possible to customize the sender and the body of the verification code SMS sent by DocuSign? I am currently using RecipientSMSAuthentication for a signer to send this SMS.
Thank you in advance for your feedback !
Nov 27, 2024 4:07 PM UTC
Hello ​@lvincent,
Are you sending with the regular Docusign Web App or are you creating the envelopes using an API?
Dec 11, 2024 10:21 PM UTC
Hi ​@lvincent,
lvincent
Active Voice
lvincentActive VoiceAuthor
Active Voice
Feb 13, 2025 10:14 AM UTC
Bonjour@Christopher.Alpizar ,
Nous utilisons bien l’API. Avez-vous une solution pour personnaliser l'expéditeur et le corps du SMS de code de vérification envoyé par DocuSign lors d’une signature à distance ?
Merci pour votre retour,
Cordialement,
L. Vincent
Troubleshooter
Feb 19, 2025 4:34 PM UTC
Hello ,
Yes we are using Docusign API, sending SMS thanks to RecipientSMSAuthentification class.
According to your documentation “Docusign signing resource file guide”, we can customize it by changing the data ActivationSec_SMSAuthCodeMessage, but its not working.
Arthur
Troubleshooter
Feb 26, 2025 1:34 PM UTC
we are still working on this point, could someone help us please ?
Arthur
Troubleshooter
Mar 4, 2025 4:50 PM UTC
Hello , ​@Christopher.Alpizar ,
could you help us ?
