Feb 28, 2024 6:26 PM UTC
Conditional logic and formula cross signers
Is there any workaround for Conditional Logic and Formula field to work between fields belonging to different recipients?
Mar 1, 2024 12:20 AM UTC
Hi @beatrice.costa,
I understand that you are looking to use conditional logic that allows you to use any recipient’s fields, and I will share more details on the topic.
You can add conditional rules that will control whether or not a recipient’s Signature Fields, appear or not in the document through our Conditional Routing feature.
With Conditional Routing you can trigger the creation of recipient roles in your signing order, based on the selection of a trigger field.
For detailed steps on how to work with Conditional Routing, see:
Add a Conditional Routing Group
Set Up or Edit Conditional Routing
Note: Some advanced features and options are supported only in certain DocuSign plans. Your account plan might not support some options discussed in this help topic.
For more information about which options are available for your account, contact your account administrator. Or, visit our Plans and Pricing web page for more details on the features included with your plan.
Hi @beatrice.costa,
