Apr 17, 2024 12:26 AM UTC
Choose between two required boxes
I would like recipients to be required to fill out either text box A or text box B? How do I set that up?
Jeff.Daviscourt
Apr 17, 2024 2:32 PM UTC
Place radio buttons and assign conditional logic to the radio buttons. This will result in the signer having to choose one of the two radio buttons, and a text box will only show for whichever option they selected.
Jeff.Daviscourt
Justin Jiang
Established Contributor
Apr 17, 2024 6:24 PM UTC
Yes, I tried it before and worked.
Welcome to the DocuSign Community and University! Your feedback is immensely appreciated. If this answer resolves your issue, please feel free to give it a Like and mark it as the "Best Answer". This helps others in the community find the information they need. Visit us at http://dsucustomers.docusign.com for more resources and support.
rperryNewcomerAuthor
Apr 17, 2024 7:53 PM UTC
this works thanks!
