Sep 25, 2024 7:12 PM UTC
Auto navigation settings developer acct > production
If I set auto-navigation within my developer account to stop at the top of each page and then go to signature, when the template is moved to the production account, will the auto-navigation settings there, override what I had programmed?  Our production account auto-navigation settings are set for all fields and I need it to stop at the top of each page for the user to read the document before signing.
Sep 26, 2024 11:52 PM UTC
Hi @REL,
Envelope Navigation settings are configured at the account level. Therefore, the template created in your Demo account will be subject to your Production account configuration, you will need to update your current selection in Settings>Signing Settings in order to correct this behavior.
Hi @REL,
