Jul 9, 2025 1:38 PM UTC
Applying my own signature to my own document that is larger than 25MB
Is there any way to apply my own signature to my own document that is larger than 25MB?  Can I access my document from my desktop and apply my signature?
Ma.CubioAnswer
Jul 24, 2025 6:34 PM UTC
Hello ​@Jenn G.
The 25MB limit is per document uploaded to an envelope. I suggest that you try to flatten the document: https://support.docusign.com/s/articles/How-to-resolve-a-document-upload-error-by-printing-the-document-to-a-new-PDF?language=en_US. You may also try to split the document and upload it to the same envelope.
Ma. Cassandra| Docusign Community Moderator
If this helped, go ahead and click "Best Answer"!
Glen.Steinhardt
Jul 9, 2025 5:52 PM UTC
Hi Jenn,
The maximum file size for a document to be added in an envelope is 25 MB.  Please view this support article for more information.
File Size Limitations for an Envelope
Please click "Best Answer" below if you find my reply to be a valid solution to your issue! This allows others who may be experiencing this issue to know what their solution might be as well! Many thanks!
Jenn G.NewcomerAuthor
Jul 9, 2025 7:33 PM UTC
This Limit seems incredibly low.  I have a proposal with 1700 pages including many graphics.  I need to add my own signature to the proposal before sending to my customer.  The file size is 96MB.  There is no way to add my signature to this document?  If i separate the page and sign it, it is my understanding that it cannot be recombined with the rest of the document, is that correct?
Hello ​@Jenn G.
Aug 5, 2025 11:55 PM UTC
Hello ​@Jenn G.
