Nov 12, 2021 12:25 PM UTC
I have a template that I have been using and shared with employees with no problem. Yesterday all the DocuSign boxes and signature/date fields totally disappeared. Does anybody run into this problem and what is the solution?
Nov 12, 2021 7:03 PM UTC
When sharing a Template and not using a password protection on that Template you risk another User editing the Template and potentially causing issues such as field removal, they may have tried to Delete and Upload a new document which would have removed ALL fields and then saved this change. I suggest taking a look at the Template "History" to see who may have edited the Template. If you have a backup (download) of the Template you could restore it. Otherwise you need to fix and save and I would suggest password protecting the Template.
Nov 12, 2021 7:10 PM UTC
How would I put a password on my template?
Nov 12, 2021 7:11 PM UTC
Edit the Template and then go to the Advanced Options button, the popup window should have a "password" option that can be used to restrict editing of the Template.
Nov 12, 2021 7:18 PM UTC
I put a password on the template. So now that I put a password on the template is that changing anything for the people that I'm sharing the document with? besides that they can't edit the template.
Nov 12, 2021 8:49 PM UTC
The Users can still "Use" the Template they cannot make edits to the Template without knowing the password.
Nov 12, 2021 10:22 PM UTC
Perfect! thank you so much for your help.
