May 29, 2024 4:49 PM UTC
How does Docusign Workflow Builder (formerly Maestro) help increase efficiency?
Limited integration hinders data exchange with systems of record and often requires time-consuming and expensive custom engineering work. How does Docusign Workflow Builder (formerly Maestro) help with this issue?
May 29, 2024 5:49 PM UTC
Docusign Maestro helps you minimize costly standalone integration projects by seamlessly extending workflow capabilities across your tech stack. Maestro enables you to easily build and deploy customized workflows that provide the necessary integrations to automate your agreement processes without writing any code.
Thanks for posting your question on the Docusign Community!
Sumit.Parikh
Jul 30, 2024 4:18 PM UTC
Docusign Maestro along with Docusign App Center enables customers to build end to end agreement process across your tech stack. You can visit Docusign App center to lean about list of integrations available - https://apps.docusign.com/app-center
