Community Admin
Jan 13, 2025 10:43 PM UTC
Trainer Tips Live: How to Apply Conditional Routing to an Envelope in Docusign | Recap & Recording
  • Feb 13, 2025 9:15 PM UTC
  • 2 replies
  • 372 views
  • Translate All
Learn how to use conditional routing in Docusign to simplify workflows and streamline approvals in this recording of a Trainer Tips Live session.
What you’ll learn:
  • What is conditional routing?
    • A feature that automatically routes envelopes to specific recipients based on rules like expense thresholds or department selection. It supports up to 200 routing groups and 200 recipients per group.
  • Real-world examples:
    • Expense reimbursement workflows: Route approvals based on thresholds (e.g., under $500, over $500, or over $2,000).
    • Departmental approvals: Ensure documents are sent to the right people based on department selection.
  • Step-by-step setup:
    • Create routing rules using dropdown menus and numeric thresholds.
    • Test your workflows in a demo environment.
    • Set up multi-level approvals, including VP-level sign-offs for high-value requests.
⚡ Watch the session to see how this feature can make your processes more efficient.
Got questions about conditional routing? Drop them in the comments below👇
mshealy
Established Contributor
Jan 22, 2025 8:28 PM UTC
Thanks for this info!
Denise
leahbCommunity AdminAuthor
Community Admin
Jan 27, 2025 5:45 PM UTC
You’re welcome! Glad you’ve found it helpful!
Leah
