Jul 31, 2025 3:00 PM UTC
Valid values for Recipient Types in Power Automate action "Add verification type to a recipient"
I tried to search and checked in documentation also. In the documentation Recipient type it says its drop down, but its just text field. if you see below picture (from docusign link), recipient type they say its drop down, but its not drop down. and whatever values i tried to give/enter like ‘Need to Sign’ or ‘Signer’, its giving error and i couldn't find what are valid values anywhere in document for this specific action. (https://support.docusign.com/s/document-item?language=en_US&bundleId=oyj1749839266590&topicId=zbo1666553138186.html&_LANG=enus)
Can someone provide me what are valid values in Recipient type for this action?
Aug 1, 2025 11:49 PM UTC
Hello ​@sjambula,
You may need to add the recipient to the envelope using “Add recipient to the envelope (v2)” action. Once that’s done, you’ll see an output for the Recipient Type. You can then use that output to select the desired type of recipient when you add a verification type to them in the next step.
I hope you find this helpful. If you believe this response effectively addresses your question, please mark it as Best Answer ✅ to help other users with similar questions and locate it more easily.
Hello ​@sjambula,
sjambulaNew VoiceAuthor
Aug 4, 2025 2:46 PM UTC
That’s smart way. So recipient type values are same in both actions. Thank you and that works.
Aug 4, 2025 3:12 PM UTC
Hello ​@sjambula,
Thank you. If my response helped solve your question, could you click the “Best Answer ✅” button below the post? That helps others in the Community find trusted answers faster.
Thanks for being part of the Docusign Community!
