Conversation Starter
Sep 30, 2024 9:44 PM UTC
Using Power Automate to apply a template to an uploaded document
Hi I am new to DocuSign.
I am trying to create a flow in Power Automate which will create an envelope using an existing template and then it will add a document to this envelope while applying the template to the document. It will then add recipients and send out the envelope.
I have created the following flow to accomplish this:
The issue is that the above flow is unable to apply the template to the added document. The final result is that the added document is appended to the sample document that is already there in the template. The fields are there in the sample document however, the added document does not have any fields. So, it seems like the template was not applied to the added document.
Is there a way to apply the template to the added document such that it has all the fields for the recipient. At the same time the sample document in the template should be removed and replaced by the added document.
Thanks in advance.
Michael.Rave
Oct 2, 2024 6:59 AM UTC
@nitish555
Unfortunately, you cannot achieve this with the Docusign Standard Connector for Power Automate, as Composite Templates are not yet implemented. You will need this functionality to upload a document and apply a template. It is possible to do this with a Custom Connector for Docusign in Power Automate and adding the API call to it. I have done this years ago for customers as part of a service engagement.
Oct 1, 2024 10:11 PM UTC
Hello @nitish555,
Besides the template not being applied and the document being append, are you getting any error messages?
Michael.Rave
@nitish555
nitish555Conversation StarterAuthor
Oct 3, 2024 4:01 PM UTC
@nitish555
Hi @Michael.Rave ,
Thanks a lot for responding.
Could you please explain how this functionality can be achieved using a composite template?
Thanks.
Oct 3, 2024 4:07 PM UTC
Hello @nitish555,
Hi @Christopher.Alpizar ,
Thanks for responding.
To answer your question, no I am not getting any error messages. The flow is able to run successfully and send out envelopes but with the issues mentioned in the post.
Michael.Rave
Oct 4, 2024 7:50 AM UTC
@nitish555
When using a composite template you can upload a document using the “document” element and then apply a server template using the “ServerTemplate” element to it.
This way you can upload a document from SharePoint, apply the template and fill out all recipients, fields, etc. in a single step in Power Automate. This requires you to set up a Custom Connector for Docusign eSignature, where you implement the “create envelope” endpoint with composite template payload.
Oct 7, 2024 5:45 PM UTC
@nitish555
Hi @Michael.Rave
With a little difficulty in setting up OAuth for the API call and figuring out the composite template syntax, I was able to send the envelopes with desired tabs on the uploaded document in Power Automate.
Thank you so much for your guidance. It was pivotal in helping us crack this.
Michael.Rave
Oct 8, 2024 7:45 AM UTC
Well done, @nitish555! 👏
Jan 24, 2025 3:56 PM UTC
​@Michael.Rave Question: I'm currently using the developer account at passing a pdf to docusign to send. I have been getting a unique envelope ID each time (this is good). but when I looked in docusign after a month of testing the demo with multiple documents, I see a single document that has been modified each time.
Please tell me that once I move to the non-demo connector, each “create an envelope” will result in a new document within docusign.
Michael.Rave
Jan 24, 2025 4:04 PM UTC
​@KatieL
Yes, each “Create an envelope” will result in a new envelope within Docusign. This is true for the demo as well as for the production environment. Before sending, this will create “draft” envelopes only and they can be found in your “Draft” folder. After sending they will be visible in your “Sent” folder in the eSignature Web App.
In the demo environment the documents will be purged after some time, as this it for testing only and we are not keeping the test documents indefinitely. Therefore, you may not see and be able to access older envelopes in demo, because they may been removed from the system automatically.
Not sure what you mean with “seeing a single document that has been modified each time”.
Jan 24, 2025 4:24 PM UTC
​@Michael.Rave What am I missing? This shows a single document with multiple revs. Each of the “sent” entries is a new test of the flow
