Oct 11, 2024 6:02 PM UTC
Template Fonts Changing with Power Automate
Hoping someone can help us here… we have a Power Automate flow that updates Prefill tabs on a template in DocuSign from a SharePoint list. All of the Prefill tab fields are set to Times New Roman Font, Black, Size 12. When the envelope is sent, it changes the font of the data in the tabs. I tried to set the font in the workflow but it didn’t work. Has anyone else experienced this?
Oct 14, 2024 2:51 PM UTC
Hello @SVDB-PowerAutomate,
Is this happening regardless of the font that is being used? Would it be possible for you to provide a screenshot of this issue?
Oct 21, 2024 5:28 PM UTC
Thank you for your response. All of our font is set to Times New Roman in the template, prefill tabs and in the workflow. You can see in the screenshot
In addition, it looks like 2 tabs are getting placed, often on top of or right next to one another. This is not visible in the mobile view but is available in the browser view. It is also visible to the recipients when signing but not once the envelope has been completed. Please see screenshot.
Oct 23, 2024 3:14 PM UTC
If the fonts are being change there is the possibility that a bug might be affecting the account, have you created a case with Docusign Support?
Oct 23, 2024 3:24 PM UTC
I do have a ticket open. Thank you!
Any thoughts on the prefill tabs and workflow?
Oct 28, 2024 10:54 PM UTC
The envelope, is it design to be completed in a mobile device or a desktop or laptop?
Oct 29, 2024 1:58 PM UTC
It should allow you to view on any device the user chooses.
Oct 30, 2024 9:54 PM UTC
Can you provide the case that you opened with Docusign Support? I think that this might be another potential bug.
