Troubleshooter
Sep 5, 2024 11:58 AM UTC
tabs are filled with the same value in power automate
Hello
In power automate I have a flow that uses docusign and I am puttin some tabs on a document. When I start typing on one of the tabs, the same value is entered in all the tabs. The anchors are all different for each tab. Moreover even if I set the tabs to optional they appear as required when I hover over them.
I’ve tried both old and new designer in power automate
kokosAnswer
Troubleshooter
Sep 6, 2024 8:59 AM UTC
Apparently if you put lables the problem is solved and the tabs are not filled all together… the optional issue persists though
kokosTroubleshooterAuthorAnswer
Troubleshooter
