Mar 6, 2025 10:21 PM UTC
refund; thought i was paying a fine, ended up switching to a monthly subscription while not using docusign for months
I had sent more enveloppes than my account allowed so the request was to pay 39 euro's to make it right. I wasnt aware that I had actually switched to a monthly and more expensive subscription. I went into labour not long after and now returning to the account i see ive been billed for the past 10 months while not using the service. I cant seem to get a hold of a person to just explain the situation as this doesnt follow the standard automated scripts for refunds.
Please help
Mar 7, 2025 12:06 AM UTC
Hello ​@Marjolijn,
We understand that you’d like to speak with one of our representatives, and we know how important this is.
Docusign Community is not the best platform to raise your billing concerns.
You need to open a case to get in touch with our representatives. You may follow the steps provided in the link below on how to open a case.
If you found the response a useful solution to your question, please mark it as the best answer by clicking “Select as Best” to make it easier for other users to find.
Hello ​@Marjolijn,
Mar 13, 2025 11:34 PM UTC
Hello ​@Marjolijn
If so, please mark it as the "Best Answer ✅" by clicking “Select as Best” to make it easier for other users to find.
MarjolijnNew VoiceAuthor
Mar 14, 2025 11:47 AM UTC
Hello ​@Marjolijn,
Thanks for your reply. Ive downgraded to the free version bit now i cant seem to open a case. Any advice?
Mar 14, 2025 3:04 PM UTC
Hello ​@Marjolijn
Yes, there was an update that only paid accounts can open a case.
The work around for you to open a case is using the same link and use the bottom part where it says “I can’t access my account”.
https://support.docusign.com/s/contactSupport?language=en_US
I hope this helps, please mark it as the best answer by clicking “Select as Best” to make it easier for other users to find.
Mar 25, 2025 9:53 PM UTC
Hello ​@Marjolijn
Mar 31, 2025 8:55 AM UTC
Hi Marco!
Thanks for taking the time. I’ve tried your workaround. I will update whether this was a helpful course of action for my dillema.
All the best,
Marjolijn
Apr 15, 2025 5:57 PM UTC
Hello ​@Marjolijn,
