Conversation Starter
Apr 14, 2025 4:45 PM UTC
pre populate fields in envelope in power automate
I previously asked a question about the Pre-fill Tools fields and how to populate them using docusign. I got this working but I misunderstood the use case for them, they dont fit my requirement.
I have a form with a number of standard fields and I would like to fill them before sending to the signer.
I have been able to use the ‘Get recipient tabs from envelope’ to get a list of all my fields
e.g. I have a standard field in the form called OrgName.
Here I am using the action ‘Get recipient tabs from envelope’
"tabType": "text",
"value": "",
"tabLabel": "OrgName",
"documentId": "1",
"tabId": "6367e668-ac81-462f-862b-26d204458056",
"recipientId": "1"
I would like to populate this with text in power automate before sending the envelope.
Is this possible?
Apr 14, 2025 5:56 PM UTC
​@nick911
Yes, you can definitely populate standard text fields before sending to the signer by specifying the value for that tab. In Power Automate, you either include the tab’s during the “Create/Send Envelope” step or do the two-step “Get Tabs → Update Tabs → Send.” That’s all it takes to pre-fill standard fields for your recipients.
​@nick911
Apr 29, 2025 9:56 PM UTC
Hello ​@nick911,
