Aug 12, 2025 4:05 AM UTC
Power automate tabs - conditional logic using built-in connector
I have scenario of conditional logic, like say there are 5 checkbox options (option1, option2, ….) and 3 sub options (option A, option B..) (which i can create using add tab action).
Now the requirement is, when user selects option 1 or option 3, then Option A is required and when user selected option 2, then Option B is required…
I see there is a way to implement this in REST API, but i don’t see option in any power automate actions, so, is conditional logic possible to implement in power automate built-in connector?
Aug 13, 2025 6:31 PM UTC
Hi ​@sjambula,
Thanks for posting your question - we're glad you're here and happy to share knowledge with you.
Conditional Logic is not a built-in function to the "add tabs" for recipient action. The options you can consider are:
  • Use a Template with the Conditional logic set. However, based on your description, it sounds like the document is dynamic, where a template won't work, so this approach might not be suitable
  • Use the REST API.
I hope this helps. If you believe this response effectively addresses your question, please click Best Answer ✅" to help other community members find trusted answers.
Let us know if you have questions, here for you!
Melanie| Docusign Community Moderator
Helpful? Feel free to hit “Best Answer” so others can benefit too!
Hi ​@sjambula,
  • Use the REST API.
Aug 27, 2025 11:19 PM UTC
Hi ​@sjambula,
How are you? I'm checking in to see if you still need assistance. Let us know if we can help with anything else.
Here if you need us!
