Conversation Starter
Apr 14, 2025 11:41 AM UTC
power automate pre filled tabs
I’m trying to populate a docusign template from power automate that has pre-fill tabs.
I have added a pre-fill field to my template an called it ‘pre filled test’
I have then run the power automate actions
Create Envelope from template
Get Document tabs from an envelope
{"tabLabel":"pre fill test","value":"","documentId":"1","tabId":"23bcd7fe-368e-4045-bc16-7c6cf3e90f73","tabType":"textTabs","prefill":true}]}
from here I have tried to update the pre-fill tab.
but I get this error;
{"prefillTabs":{"textTabs":[{"requireAll":"false","concealValueOnDocument":"false","disableAutoSize":"false","localePolicy":{},"documentId":"1","tabId":"23bcd7fe-368e-4045-bc16-7c6cf3e90f73","errorDetails":{"errorCode":"TAB_NOT_FOUND","message":"Tab specified was not found.  TabId: 23bcd7fe-368e-4045-bc16-7c6cf3e90f73."},"tabType":"prefilltab"}]}}
Ma.CubioAnswer
Apr 15, 2025 3:53 PM UTC
Hello ​@nick911,
Upon checking, the issue you encounter could be unusual behavior that needs to be checked thoroughly. For further assistance, we recommend for you to create a support case instead.
The workaround is to submit a case without logging into your account by using the “I can’t access my account” option at the bottom of the page and providing complete details of the issue in the Case description.
https://support.docusign.com/s/contactSupport?language=en_US&rsc_301
"Select as Best" below if you find the answer a valid solution to
Hello ​@nick911,
Apr 29, 2025 4:16 PM UTC
Hello ​@nick911,
