Apr 28, 2025 7:43 PM UTC
power automate "Get recipient tabs from envelope" radiogroup missing tabLabel and tabId
I am using Power Automate to retrieve fields from a completed document; however, all the “radio group" fields are missing “tabLabel” and “tabId” information. Please advise.
Ma.CubioAnswer
May 1, 2025 9:14 PM UTC
Hello ​@Aleksandr-8543,
Those elements are missing since you are using docusign trigger then you should use the output of "tabs" in the workflow instead.
May 16, 2025 4:26 PM UTC
