Apr 28, 2025 2:44 AM UTC
Power automate and DocuSign
Hello Everyone,
I’m able to create envelope successfully to send a document for signing using power automate. I receive the email to sign the document. I’m able to open and sign the document successfully. I also get the completion of signature email. However, when I open my DocuSign account, I don’t see the envelope anywhere, why? What am i missing? Any advise would be helpful.
May 5, 2025 4:39 PM UTC
Hello ​@Hemanth Dakshinamurthy,
​Thank you for reaching out, and a warm welcome to the Docusign Community! We are absolutely delighted to have you here and can't wait to share our knowledge with you.
I understand you can't see the envelope on your account, which was sent from Power Automate. I sincerely apologize for this, and let's work together to sort this out.
Do you have multiple Docusign accounts? You could be logged in on the wrong account. Please try the following to resolve:
First, Switch Between Docusign Accounts
  1. Select your profile image to show the account actions menu.The account listed below your image is the current one in use.
  1. Select Switch Account.
  2. In the Select an Account dialog box, select the account to switch to. Docusign refreshes and loads the selected account. The new account selection displays at the top of the account actions menu.
Next, follow this article for searching the envelope: Search for Envelopes
Lastly, Set a Default Account
If you have multiple accounts and can switch between them, you can select any of them as your default account. When you set a default, you will always start in that account when you log on.
To set a default account:
  1. Select your profile image and My Preferences.
  1. In General Settings, locate the Your Default eSignature Account section and select Set as default.
  1. ​Your new default account is set.
Articles:
I hope this is helpful to you. If you consider the response above useful, please click “Select as Best” to mark it as the “Best Answer ✅.” This will assist other users with similar questions in finding it more easily.
Let us know if you need further assistance with this. Thank you!
Hengfeng Ge
Hero
Hero
Apr 28, 2025 4:07 AM UTC
Do you integration power automate with same user as you login Docusign web console?
FreeLink/甫连信息
Articles:
May 19, 2025 10:22 PM UTC
I trust all is well. I want to confirm if you were able to solve your issue by utilizing the suggested solution or if the information provided was useful. If so, please mark it as the "Best Answer ✅" by clicking “Select as Best” to make it easier for other users to find. Please let us know if you need further assistance. Thank you!
